I am on a MacBook Pro and I cannot see all the icons in the right shelf by the document window. I can see there are more icons (one is only half visible), but can see no way to scroll them up. Suggestion please?
Thanks,
Cris
P.S. If I am working on an object that I have made in an external program that has UVs, do I need to assign them or does ZBrush know to use them when I am using Spotlight, Image Plane of Polypainting?
My normal workflow, from working with Image Plane, is to bring in the plane, add my geometry, subdivide to 7 and ZProject brush to paint from the Image Plane, use Projection Master to add materials/shaders, drop it, pick it up and choose New from Polypaint in the Tools Texture palette. Normally, that gives me a map based on what I painted when in 3.2, but in 4.0 it is stretching the texture into stripes.
