Need help with exporting Normal maps from ZB. 3.5
I’ve exported this low poly model into ZBrush 3.5 and I’ve added some details without changing its shape.
Now I just need the use the normal map.
I clone the normal map to export it but nothing happens when I click the export button!
I’ve been doing hours of searching but I had no luck at all!
How do you export NM Map in ZBrush 3.5?
