Need help Saving and Exporting UV Maps
I used UV master to unwrap my mesh and then i painted my model with polypaint, so my question is: “How do I save and export my maps from ZBrush”?
Is there a ZB video tutorial that explains it or can someone please explain the steps for me. I only need to export disp. normal and diffuse (color) for now.
Try Multi Map Exporter.
Thanks Zber, I will use this plug-in most likely but before I use a plug-in I want to know how to manually export the maps in ZBrush so I understand the process.
Can someone please post a video or tutorial or explain the steps to exporting a Displacement, Normal and Diffuse map from ZBrush!
