Need help installing plugin and a problem i have
Hello all, I am a new zbrush user, I must say that i love this program; feels natural. However, I recently downloaded the transpose plugin, I need to know where I put each file that came in the .zip at. Also i have noticed that when i am doing anything with zspheres, that the thing i am making will sometimes fly off into a random area and get very small. I have tried moving it back and various “workarounds” that I have seen on these forums and I also already know that there is not a fix for this problem yet. Now when I mess with zspheres that the same bug happens but then it will crash before I can fix it, great program otherwise. Will this bug be fixed in the new version coming up?
From what I have seen through my searches this problem is serious.
Installing Transpose Master:
  1. Unzip the downloaded file to your desktop.
  2. Open the folder and locate the TransposeMaster.zsc file, ZFileUtils.dll file and the TPoseMasterData folder. Move these to your ZBrush3\ZStartup\ZPlugs folder.
  3. Restart ZBrush and you will find a new Transpose Master submenu in the ZPlugin menu.
On the ZSphere issue (which will be fixed in the next update):
  1. Press ‘F’ on the keyboard to recenter the model.
  2. If that doesn’t work you could try this:
  • Press ‘T’ to leave Edit mode.
  • Press Ctrl+‘N’ to clear the canvas.
  • Draw your model on the canvas. Press ‘T’ to enter Edit mode and continue modeling.
HTH,
Thanks very much it worked, now i get to fiddle with this.
