Nee help or advise
I m new to Zbrush but strugle with something. I will give sample and hope you can help.
I make cube from let say 100x80x50 make it a poly mesh and increase div to lets say 6. As far as I know sumetry is OFF. Then I want to place a mask on ONE side (face) of the cube ONLY. I then could do extract or example inflate.
Now the problem. For some reason the mask and action thereafter happens on two faces (front and back) of the cube. I know maybe basic thing but I cant seem to solve it. Hope you can help
Thks stephan
Hey there Stephan,
just go to top Menu Brush and go down to the auto masking tab. In there click on backface masking. That should do the trick.
Hope that helps.
thks you so much works like a dream. You helped me super
