All of sudden recently my Zbrush is using from 90%- 100% cpu usage. I dont understand. I have 8gb ram with a quadro.
well you can set 3 cores of your computer to use zbrush or 2 cores etc.
heres how
you have to click [ctrl] [alt] [del] at the same time and a box will apear right click on zbrush and click [set affinty] and set your cores to 3 or 2 or even one core all up you
hope this helps
Hey this sounds it wud help. When I clicked on affinity it says access denied, and I am the admin. Is there any other way around this?
well i did not see this comeing if you anser thes qestions maby i can help
did someone else instal zbrush on your computer?
where you not on admin wen instaling it?
are you on admin now?
because its not leting you set anffty it means its part of your system thats not good you system thinks it needs it to run look at the picture i posted procees says system some says delta. delta is the name of my computer
the ones that have the name of your computer is the ones that you can edit
heres anater trick you can try
above [set anffity] theres priority try seting it highter that might help
if it dont help anser what i ask i will try to help
