amazing skills, your humans seem to be alive, i especially love the old guy, seems so sympathetic
Pretty awesome sketchbook wandongxu , great models and renders
Keep it up
Terrific work
Pinkman
Amazing works ! Really inspiring!
Walter looks alive ! Would love to see Walter with Pinkman together !
Could you please share how could you get such amazing pores and wrinkles, are you using any magical alphas??
WOW great great works man!!! thanks for sharing bro very inspiring!!
Thanks Th3estric and jmturbo.I used brush and alpha all in zbrush
thank you Wandongxu!!!
What was this rendered in? Amazing portrait, willing to share your lights and shader??
Outstanding work!
I was render in maya by vray
thank you so much thats amazing!
I use 3ds max but I will find a way to try this amazing Shader with the vray materials in that.
Thanks again!
Hey man, good stuff, I hope you don’t mind if I offer a couple suggestions about the shader. Some of this stuff is personal preference so if I say something you dont like feel free to ignore me.
Seems like the spec is tinted blue, which breaks the physical correctness. If you need the blue in the spec its better to use a dome light or area light with an open sky or giving off blue light/spec.
Checking the ‘fresnel’ checkbox in the vraymtl shader (for specular) doesn’t create quite accurate fresnel effect when you layer it in the shader. Instead, Keep ‘Fresnel’ unchecked, and use a fresnel node in the blending slot of your VRAYBLENDMTL instead. Here is a small diagram, the fresnel node version create what is supposedly a more accurate effect on the contours.
- Correct spec requires a lot of contrast in the gloss and the specular, I think you’re missing out on a lot of good reflections (which help sell the skin alot) by using just a gloss parameter of .7 - It looks like you’re trying to correct yourself by using a second specular map for stronger reflection in the middle of the face but it would look better and be more accurate to just use a gloss map with a lot of contrast to keep from trying to have to layer reflections on to fake it.
Anyways thats all, good stuff seriously.
Wow! beatiful anatomy and renders you have there.
Amazing work all over this thread!
Superb suclpting! Thanks for sharing the wip images.
really beautiful sculpt!
Very cool, looks like a hand painted figurine. Well done
