My brushes go thru the geometry :s
Hey, i get this issue when i’m sculpting with for instance a “draw rectangle” with an alpha and mode set to Zadd, the other side of my model gets the Zsub :s Like the brush influences the whole object, not just the surface.
The only way i found around is, is to mask the other side of the model. It’s probably one button i’m missing… plz help
i am assuming you’re sculpting something very thin
brush>backfacemas (it’s auto back face masking) if a brush’s radius is bigger than the thickness of an object it effects both sides. this button will prevent that.
Two guys were walking through the jungle. All of a sudden, a tiger appears from a distance, running towards them.
One of the guys takes out a pair of “Nikes” from his bag and starts to put them on. The other guy with a surprised look and exclaims, “Do you think you will run faster than the tiger with those?”
His friend replies: “I don’t have to out run it, I just have to run faster than you.”
cheap wow power leveling --------------------------------
buy eq2 plat, eq2 gold, everquest platinum, rs gold, silkroad gold,
