Hi all,
I’m busy following a tutorial about using multiple UV maps in Zbrush. I made the mesh and uvs in Lightwave, and exported as an obj. I have then opened in Zbrush and done a “uv check”. If you look at the first image You can see the uv layout in Lightwave. The second image has the uvs applied but as you can see they haven’t been applied properly and the tutorial doesn’t say how to fix the them in Zbrush. Does anyone know how to go about this…?
Any help would be great. Thanks!
