Multiple spheres in one scene help
Hi folks, this is my problem, after morphing a sphere into a face with holes for where the eye balls should go. I tried to create spheres for the eyes using the subtools thru the append tab. I get the spheres however, they are superimposed over each other. When I click on a subtool sphere making it (I think active) and try and move and scale it, everything moves together, I cannot move anything individually. I have the trial copy of ZBrush.
Also, if I make one of the primitives useable for morphing all the other spheres in the subtool are deleted. Jan
To move the eye separately you need to use TransPose. This is explained in the online documentation. See my signature.
The best way to do what you want is to append one eye then move and scale it into place. Then you could use SubTool Master to clone and mirror it for the other eye. However, SubTool Master is only available for the commercial versions of ZBrush rather than the trial.
