multiple materials export
Hi!
I’ve been away from ZB for a very long time and now have a complete newby question.
So here’s the thing. I have two rings (seperate), one inside the other. In Zbrush I applied a different material to both… I then merged the two subtools with UV selected into one object…so far so good.
So then I export my object as an .obj, but when I open the object in Keyshot, there is my object, no problem but there is only one material for the entire thing… not two.
How do I export out of Zbrush with two materials to two objects?
HUGE thanks!
M
ps if you could explain it to me like I’m a complete idiot that would be most appreciated.
sounds like a keyshot problem.
:smiley: thanks for that
Its ok I figured it out, import settings in Keyshot…I didnt go to advanced. S’all good.
