Multiple FBX import
Hi!
is there any way of importing multiple fbx as subtools? I need the vertex color information that Zbrush can import from FBX files, but I have a photogrammetry model divided in several pieces (around 50), so I need a quick method to import all.
Thanks in advance!
If a single FBX file has separate meshes then they will be imported as separate subtools but if you’ve got separate FBX files you’ll have to import them one by one.
would be easy to create a script to import multiple fbx? any tip about it?
No, it won’t work. You can’t call a plugin from a script.
