Hello everybody
I have sculped a mesh and need to export a displacement and a normal map.
I tried multi map exporter, but it gives me some strange results.
(strange lines all over the place)
Why is that?
When I try the “create normalmap” button in the Tool menu, it works way better… but then it’s only a 2kx2k map… but I need a 4kx4k… so that’s why I wanted to use multi map exporter…
Any ideas why that is creating such strange lines?
What are the best settings to export a displacement and a normal map with that plugin?
Or other question: How can I make the normal export in the tool section make a 4k map?
Thanks a lot
Oliver
