Hey y’all!
I need to make a diorama with many character in zb. I tried to use decimation on them but It didn’t keep the polypainting.
What would be a good way to go if I want to pose them in a single ztool.
Thanx!
Hey y’all!
Thanx!
You can keep your polypaint with decimation master if you go to Preferences>Decimation Preferences>Keep Poypaint
However… the quality of your polypaint will be determined by the decimation amount. Its kind-of a paradox!
If you wanted everything merged into one subtool so you can pose it, try using Transpose Master. It merges all the subtools together and you can pose it. You can export the single mesh (it will be your lowest subDs) or you can transfer the pose back to your subtools. Otherwise you can just do a “Tool>Merge Visable” to create one subtool for each model.
