Newbie here. Recently I’ve been having problems moving the entire Zbrush window. The four arrow cursor (vertical, horizontal) doesn’t appear anymore and I can only manipulate the top, bottom, and sides, but can’t move the entire window itself on my desktop. Thanks in advance for your advice.
](javascript:zb_insimg(‘214623’,‘this.jpg’,1,0))
I think you cant do
zbrush doesn’t show you the cursor change, but if you click anywhere at the top of the application when in windowed mode you can move it around like any other app.
you can also scale it…which i believe you’ve found…the same way as any other app.
Thanks to you both. I just hit the DefaultZscript and the “pointed” cross returned. Wonder what disabled it originally.
