Moving PolyPaint around?
Is it possible to move polypaint around without affecting the geometry? Ideally setting ‘rgb’ on and turning off ‘zadd’ on the move brush would do it but it doesnt work…
as far as i know ,only if the polypaint is painted by the “editable curve brush” can be move freely.
OR you can enter projection master,use SMUDGE brush (turn focal shift to -100 and RGB intensity to 100 for avoid edge blur) to move polypaint.BUT this method not very good…:confused:
after projection master smudge:QQ截图20131205221827.jpg
