Moving a single zpshere
I cant seem to be able to move a single zsphere after drawing it on 4r2 anyone else having this problem?
I draw one spehre go into Edit mode, draw a link and when I try to move the new one the previous comes with it.
More info needed.
There is only one zsphere on the canvas, and you can’t move it?
OR
You can’t individually move a single zsphere in a chain of zshperes?
Does this happen if you close the program, and start from scratch?
Reduce your Draw Size so that it doesn’t affect more than one zsphere. If you are moving a chain then hold Alt and click+drag the link spheres to move the chain.
Thanks for the response Marcus, I was already aware about the size setting needing to be at 1 I think my problem is if I zoom out a little bit it seems that they may have changed something previously I would zoom out and still be able to affect only 1 zsphere. For now I need to zoom in relatively close.
