moveing one object to anothers position?
is there a way to move a poly oblect to the exact same position as another object. in other 3d software id set the pivot position of the object in world space values. but im not sure how to do this in ZB. am i missing something?
thanks.
Load your first object, edit mode.
Under Marker Palette, turn off MARKER:Tool.
Mark your object position (press M)
Load your second object, edit mode.
Click on the Marker. Your new object will assume the position of your original object. You may want to toggle off some of the other attributes in the Marker palette as well, depending on what else you want the new object to inherit from the original…
I think that’s what you want to do?
Sven
