move2 brush,
hello,
i am trying the planer tutorial where themove brushes are described and the cat demonstrating the brushes is referring to a “move2” i dont have that,actually i dont have alot of the brushes that have been mentioned, is it a down load? an adjustment? was up.
thanks
move2 brush isn’t preloaded by default, but it is definitely installed with r3.
to use the Move2 brush, drop the lightbox down, select the ‘brush’ category, then scroll over to the M’s and you’ll see Move2.ZBP there. double click it and you will be good to go.
many thanks Testure,
Remember, if you want to save a brush to your brush palette that you normally have to access through lightbox; You can just select the brush you want from lightbox, open your brush palette and hit the “Save As” button, enter a name, save, and you your brush will stay in your palette even after you close and re-start Zbrush :slight_smile:
That was my next question,
psychic
