OK, I think I missed the memo on this. What happend to the move tool? When I click on it (or press W) I get the three circles for the “trans pose” tool. In the past I would hit “W” and pull out geometry. Wha-happen??
Thanks,
-Dooki
Thanks,
-Dooki
its the tweak brush now. move/sculp/rotate is the pose-tool now.
Thanks.
Very interesting though. When I wrote the email I was using the default setting for “rapid” set up. This of course places a sphere in the center. AFTER posting the thread I deleted that sphere and loaded a new from the tool pallete. I then clicked on the ‘move’ tool using the submenu (right click) and was able to push/pull like before. I then presse ‘W’ and again was able to push/pull. I then quit and re launch ZB3. Ony this time I got the same transpose circles with both the default sphere and newly loaded sphere. Strange!
I will look up that "tweaK’ tool. Thanks.
-Dooki
This is quite a common thing. I just ran into the same problem. http://www.zbrushcentral.com/zbc/showthread.php?t=45039
ZB2 has set it’s scars …
Frode
Well I know found the tweak tool. This is still kind of a drag because I used to hit ‘Q’ ‘W’ for draw and move. Now I have to break the work flow and reach over for the tweak tool. Is there a hotkey for tweak?? THanks.
-Dooki
