move brush, all high, activate subtool, CRASH
I can repeat this bug.
The bug is for Zbrush 4, OSX.
  1. open zbrush
  2. open ztool, make editable
  3. select the move brush
  4. hit the ALL HIGH button (under tool menu)
  5. hold alt and LMB a subtool to activate it.
  6. use the move brush on newly activated subtool
  7. CRASH
This crash happens every single time, on multiple iMac computers.
Hope this helps fixing the bug.
Thanks Brandon,
This is a known issue which is being worked on by the development team.
In the meantime, if you have the latest version of SubTool Master (03b) you can use the Hi Res/Low Res Visible options.
HTH,
Ah hah. Thank you.
