More ram is a fast zbrush??
I, i would ask if i put more ram in my pc, from 16 to 32gb…this will make my zbrush(64 bit)and keyshot sw faster?? Thx
16 is already a large amount of memory. I don’t think it will make it faster. What will happen is that it will not be slower if you work with huge files and heavy multitask. You only will notice it in these cases. I have 24 gb and I reach frequently the limit of memory, but mostly because I run lots of programs at same time. Only chrome can get lots if you open several tabs.
Zbrush also can use temporary large amount of memory if you do some operations with very high poly tools.
I would say that if with you current working style never see the memory being depleted checking the task manager (because working with moderate size files, medium multitasking) then the benefit will be 0.
Thx a lot for info Altea…
