In my job, I size things in MODO, GoZ them to ZBrush. In ZBrush I have been using whatever it takes to get the files done…Dynamesh, subtools, IMM brushes, etc. NEVER resizing the main sized piece. BUT when I am finished with the job I export out an OBJ to produce a CLY file in Freeform to be sent out to repoduce. My OBJ comes into Freeform at about 10-15% the correct size. IF I go back to my ZBrush file and use GoZ to send over something that is to size in MODO to measure from, my ZBrush file will have changed size…? This has happened twice now, but both times I can at least get something from MODO to size my ZBrush file correctly but it’s very annoying. I keep thinking Dynamesh might be doing something odd to the size…? Maybe I dont understand it enough yet…?
I work with sculptors that are using Modo, Rhino and Freeform…i’m the ZBrush guy so if someone could help, it would make it alot better on me that my workflow doesnt take longer than theirs. Thanks!
