Modo Mesh Fusion to Z Brush issues...
I posted this both here and on The Foundry forums to see which software is giving the issue, if anyone knows. So, here’s the situation…
When I make a mesh fusion from Modo and export to Z brush, no matter what I do in Z brush, the intersections of the mesh are separate. I use Zremesher, Dynamesh, polygroup everything to one group (I have tried a lot of stuff but maybe missing the right combo). I go to sculpt and the seams from the mesh fusion separate. Anyone have this issue, a solution, any help at all would be great. If this doesn’t make sense, let me know. I will upload screenies in a while when I get back to my machine.
:slight_smile:
Got this figured out thanks to help from someone on The Foundry website. Needed to export mesh fusion as air tight final vs. draft. unwrap UVs and select “segment by parts” to maintain poly groups. In case anyone else has this problem.
