Hi i am self learner in zbrush … i have a question i was trying to find a way to draw the earth planet and extude it from the sphare …
i wanted to do it by masking but is there a better way like using the alpha masking plz help
i got a reply from
aurick
The easiest is to take a Mercator projection height map of the earth (which you can very quickly find via a Google search) and import that into the Alpha palette. Assign spherical UV mapping to a sphere and Tool >> Masking >> Mask by Alpha. Now you simply use an Inflate or Size deformation to get the 3D results.
i try it but it didint work or the steps i took was wrong can any one guide me step by step plz and is this thing same as for the cylinder also
hope to get a reply plz
