Modeling Hand Wraps
How would I go about in modeling handwraps in zbrush? I modeled the basic shape in maya and brought it over to zbrush. I added details by masking strips around the object, but I don’t think this is the proper way to do it since remasking what you masked before is not possible right if you unselect it once. Right?
So whats a nice trick in doing this?
If your model has UV mapping assigned, you can save the masks by using Tool>Masking>Create Alpha and then reapply it later using Tool>Masking>Mask by Alpha. Just save the created alpha, and apply it again later.
Thanks aurick, I’m going to try that. Sounds like a very cool trick. :slight_smile:
I just did something similar for Thor’s boots here:
I found the Clay Tubes brush to be essential. By first pressing ALT to dig into the surface and then release ALT to build it back up it creates a pretty cool textured look with edges that seem to curl around the strap and add depth.
:slight_smile:
Hey awesome, thats exactly what I’m trying to do. Ill try the clay tool also. Im testing out the masking technique right now.
Ryan,
I’ve seen a couple of your videos and I gotta tell you, something about the way you work really resonates with me. You mentioned something in the Rasp video I think, it was about “leaving the tool marks in the piece” and I decided right then and there that come pay-day I’m buying some of your Gnomology stuff.
Great tip on the straps, I ran into a problem with bear claws tonight and this would have worked perfectly. Going to try it tomorrow.
ps. I am not a stalker. :stuck_out_tongue:
