After finally completing my model in Zbrush and setting up my UVs within Zbrush, my model has disappeared. I tried frame tool, then look at preview to see if the origin has been moved and it wasn’t, and unify. Is there a way to get a view of my model again within Zbrush? Help me and my sanity =[
Did you try Undo?
yes, the model still did not appear
Do active and total points show? What did you do before it disappeared? Is the background color the same as the model?
I specifically morphed uvs and turned to view them. they disappeared and I unmorphed them. That’s when I encountered this problem.
The points show.
Morphed uv’s how? You using layers? Maybe there’s a project in the quick saves folder.
I made UVs through uv master and then morph uv to be ableto see the uvs.
I am not using layers.
True, went back to a previous save I saved that is close to the one I lost. I only have to redo two things. Thank you for trying to assist me.
Under Display is Flip and also Double sided. Try them?
I tried that and it didn’t appear.
This may be a case to email support. Need steps to try and reproduce. Screengrabs with overlaid text help on here.
