I have been trying to split my model into 3 sections .This way I can increase the poly count for each piece according to the amount of detail I will need in each section. So I selected each section and hit “group visible” until I had 3 different groups.
I then “split groups” into subtools. The issue is when I increase poly count for each section ,(after they are in subtools)
Problem:
The model has a space (gap) between each group section. Even if I subdivide each piece to the same sub d level.
Anyone know how to split your model into sections so you can increase poly WITHOUT these gaps?
Thanks!
