Mirroring and welding re-topology?
Hello,
Amidst the process of retopologizing a high poly model I found out
that I forgot to turn symmetry on so I have only a half. :o
Instead of starting anew is there a way to mirror my half and merge
the two so that I still can use projection for the underlying details and
do more retopologizing?
Thank you
Export your low poly mesh that you created to your 3dapp, fix it, mirror it, then import it and project your details.
That is of course also a possibility claps forehead
Thank you :slight_smile:
