Mirror subtools work around needed
Hey all,
Here is my problem.
I have a subtool with subdivisions that I need to mirror over to the other side of my characters body. I am using Zbrush 3.5.
If I export everything back to Zbrush 3.1, reproject, and use Subtool Master, I lose my subdivisions on the mirrored object.
Any thoughts or work arounds??
Matt
not sure if it will work as I don’t have Zbrush in front of me.
you could try duplicating your subtool exporting the lowest division out mirroring it in a 3d app and import it back in. Not sure if that will work or not.
you need to go to the highest subD level.
delete the lower subD levels (tool>subtool>geometry>deleteLower)
tool>deformations>mirror
select that subtool and go to (tool>subtool>geometry>reconstructLower)
Before you do all of this you’ll want to clone the subtool and append that in first…otherwise you’ll just move the one object to the otherside.
Thanks dude. :+1:
