Minor problem with windows/palettes
When you click on a window, such as the brush palette, what happens to me a lot with both tablet and mouse is that the window opens then immediately closes. I understand that you have to keep your mouse in the window for it to stay open, but it doesn’t always work.
Is there any way around this? Some way to force the window to stay open for a second or two?
You can increase the “safe” region around the palette by adjusting the Preferences >> Ui >> Pulldown Border slider.
However, it sounds like what’s happening is that your clicks are being registered as double clicks rather than single clicks. That you will need to adjust through your system settings.
http://docs.pixologic.com/reference-guide/preferences/interface/
See open close duration.
