Micromesh - limit to the number of polys?
Is there a limit to the number of polygons a micromesh can be? I ask because I can get it to work with a micromesh that is 500,000 polys, but if I try with a micromesh that is around 2 million, the micromeshes are not rendered - after BPR the screen is blank. This happens even if I use a one polygon support subtool so that only one instance of the micromesh is to be rendered.
Also, if there is a limit, is it possible to increase this through Preferences settings?
