micro mesh problem
[video=youtube_share;T6Gb3X_2K7M]http://youtu.be/T6Gb3X_2K7M[/video]
micro-mesh welding
another video explaining it better [video=youtube_share;oBjRKbUad48]http://youtu.be/oBjRKbUad48[/video]
You could try increasing the Tool>Import>Weld value before importing the OBJ. Push the slider all the way to the right.
Also when you create the extract make sure the Tool>SubTool>EXtract>S Smt slider is set to 0, otherwise the holes could get filled in.
I found out you don’t have to export or import. I just hit the weld button next to the micromesh… It seems all the old tutorials pixologic has up need to be updated. I was also told import, export to weld is no longer needed
is this true
That will work if the points to be welded overlap but it won’t work if there is too big a gap between points. As your mesh didn’t work the old way I think it unlikely it will work the new way. Or did it?
