mesh projecting issue ... screwed up results
hello,
please help me solving this problem …
i altered my mesh and just added some polygons without scaling or reposition or any other change just bridge und new polygons and every time i try to project it into the ztool it gets screwed up … also tried goz with c4d but still didnt helped although i saw videos with goz where you had no problem changing the mesh …
any idea what could be the problem or solve it?
its looking like this btw:
http://i51.tinypic.com/2wphsib.png
<img src=“http://www.zbrushcentral.com/pixo/atn.gif”>
projections usually have errors around open geometry. There isn’t enough resolution from the LP to the HP for the rays to cast the correct direction so they continue to raycast until hitting a surface.
you can avoid this by masking that area before you project and resculpt the edges around the eye. you can also store a MT before you project, project, switch MT, then use the Morph brush to bring back the detail avoiding the areas that have problems with the projection, then resculpt those areas.
hope this helps.
