Mesh mess up
After saving my tool and saving my scene I got a messed up mesh. The picture shows the tool in Subd1 and Subd4.
Can anybod y tell me what I did wrong?
Thanks
It looks like the file has become corrupted. Which version of ZBrush are you using? Which method did you use to save?
Did you do any re-projection, projectAll, or reproject higher? I’ve sometimes see this when projection parameters are not set correctly.
I´m using the latest demo version. I get the problem alwas after saving the tool. When I undo one step after saving it works fine. All my saved tools locks the same.
I did not do any projection. But its an imported object created in modo mybe thats part of the problem?
Thanks
how big is it in the tool: preview window?
what did you do to the model previously?
i agree with Aurik…looks like a corrupt file to me…go tthat from time to time when you save…only chence you got iis if you saved a previous version on a different name?
maybe aurik got a way around, i’d love to here about it :slight_smile:
