Mesh join at higher subD
Not sure how I arrived at this, but I found myself with polys that were connected at the higher subD level that were’n’t present in the base mesh. Please see attached image.
Does this kind of thing happen often, how do I get rid of it & do I need to speak to a doctor about it? :lol:
Your mesh might be corrupted. Have you tried seeing if the stray polys are a different polygroup? If they are you can easily delete them. Also, if your low poly mesh is bad, try ZRemesher first before subdividing.
