I can see there is option trails in mesh insert brush but how can I make it work. Basically I need to create stitching made of small thread objects.So I panted to paint a line of objects. Is it possible with brush mesh insert. I can’t figure it out.
I don’t think there’s a way to use the Insert brush along a path. Is there any reason why you can’t use one of the Stitch brushes (see in Lightbox under Brush>Stitch) or make your own with a different alpha? You will need a fairly high density mesh to get good results.
