Mesh inert problem
Hi
Idon’t know how to use the Insert Mesh Brush.
The help says :“The Mesh Insert Brush inserts into the current model an instace of the mesh selected by MeshInsert Preview…etc”, but where is this “MeshInsert preview”. I can’t manage :cry:
Can > somebody > help > please ?
I run z-brush R4.
Select any Insert Brush go to Brush Menue-Modifiers click on the preview window. Or just “m” after selecting any Insert Brush.
It works, thank you.:smiley:
I did not understand the shortcut “m”. Nothing happens:rolleyes:
IF there are more than one insert mesh. Insert MM has that submenu.
Here is an example:
Go into Brush palette and select the ‘IMM Ind. Parts’ brush. Now press the M key on your keyboard to get a palette with all the parts of that IMM brush. You can select which part you want to use from that. It’s the same as clicking on the ‘MeshInsert Preview’ in the ‘Brush>Modifiers’ subpalette.
