Merge Visible/GrpSplit vs Transpose Master..
I’m sorry, but I don’t see the difference between the 2. Messing around with the ‘demosoldier’ model and Ryan Kingslien training dvd, merging multiply objects, then rotate and move the model, then split 'm up again into subtools. They seem to do the same thing!?..
they are the same thing. transpose master just makes it easier to maintain your subD levels and is very helpful if you have a ton of subtools that would take a long time to do it normally
Ok, I see. Thank you for your reply!
