Memory (RAM) Question
Hi, (sorry for my English)
I’ve 8GB Ram on my PC, why in zBrush not let me see this 8GB Ram? I see just 4GB:
http://s7.directupload.net/images/140325/qz879q4s.jpg
It’s because ZBrush is still a 32 bit app and can only use 4G RAM maximum. ZBrush 5 will possibly be 64 bit.
Oh, ok… thx. That i’ve forget. If comes out that new Version and is the Update then Free?
I’ve again a other little Question:
What am I doing wrong. I see others can up to 6 Divide. I can just up 4 Divide. Also if i do it in the Mem options the MaxPolyPerMesh up to 50.
  1. Yes; As far as I know. But maybe not.
  2. No pics, hard to tell. Maybe your starting count is higher.
1.) Yes free, ok. But when?
2.) Yeah, that was, thx.
I’ve now deleted the subdiv Levels at the Model and set the Model then in Dynamesh Modus, with 800 Resolution. Then i’ve with Ctrl + right click on space, for close posible invisible holes, then i go out from Dynamesh and i’ve make then the zRemesher with [Same]. And then i’ve set again new Divide Levels. This has worked. (= No Holes more in zRemesher).
3.) Sorry, again an other little Question:
I’ve set my mesh new with zRemesher, but now i’ve holes in this zRemesher new Mesh. What i’ve to do now?
I’ve klick the [Close Holes] Button, in the Modify Topology. But this help just a little bit close the holes.
Screen grab of the issue(your entire UI) would help. Are you using the latest version of ZBrush? It should say ZBrush 4R6 P2 at the top. Documentation folder inside your ZBrush directory with PDF files. Forums here are searchable as well as documentation linked below my post. HTH
Yeah, thx.
Yeah, i’ve ZBrush 4R6 P2.
I’ve found this Folder with this PDF Documents now.
In this Folder just now seen he have Updater File. For an automatic update-search?
No ok, I understood… i search here in Board. Thx anyway… :slight_smile:
Can you tell me what your source is that ZBrush 5 will be a free upgrade. AFAIK, Pixologic has not divulged that information.
Zbrush 5 upgrade may or may not be free. So far Pixologic has given us free upgrades, so even an upgrade from version 1 to the current version of 4R6 is a free upgrade. Like Zber says though it has not been stated if this will also be the case with the next major version 5. Pixologic has stated in the past that their upgrade pricing structure may change.
