Memory in Zbrush..
In memory settings in Zbrush i saw max amount of 4096 Memory.
In my computer i have installed 8 Gb. How can i increase the usage in Zbrush of installed memory?
ZBrush is a 32-bit app. The maximum amount of RAM that it can use under a 64-bit OS is 4 GB. That’s still twice what a 32-bit OS allows.
The extra 4 GB that you have isn’t wasted. Your OS and any other apps that you might have running all need RAM. So ZBrush will be able to fully utilize the 4 GB that can be given to it.
so, Zbrush max use 4K of Memory… because of it’s a 32-bit app…
are there any scripts, plugins that can change usage of memory up to 6Gb?
or may be a 64bit Zbrush exist? :smiley:
