So, it seems that for no reason I can tell, from time to time GoZ to Maya just decides to poop out this error and not send anything over:
// Warning: file: C:/Users/Public/Pixologic/GoZApps/Maya/GoZBrushToMaya.mel line 84: Errors have occurred while reading this scene that may result in data loss.
Sure, I can export an obj and have workarounds which get me through the job, but this is really annoying, especially since it’s something I have found no rhyme or reason to. Sometimes it just happens. And when it happens, doesn’t matter if I rename the subtool/tool, break it apart and merge the parts back together, try using a duplicate… nada. Zilch. Nothing. Once a model has this problem, the problem seems to be there to stay, at least until I export an obj, import that into Maya, then send that from Maya to Zbrush. From there, it usually works via GoZ again…
Anyone else run into this?
