Hello pixologic team,
first of all: thank you joseph drust for the noisemaker tutorial and
for giving us a new skillset.
I´m not sure, but i think i found a bug.
i´m on osx 10.10.2 / macpro 2009 xeon workstation
i tested this with both versions 32bit/64bit and it occurs on both
versions.
problem:
if i use noisemaker without adjusting the offset slider, the flip vertical, flip
horizontal switches, everything works well. i get the same results in bpr
as in the normal viewport.
after touching some of these buttons / and the offset slider the rendering
in bpr looks different than in the actal viewport.
i tried unify, switched on double sided face draw mode.
maybe i´m doing something wrong ?
thank you in advance.
cosmic
