Maya will not Launch when GoZ button is pressed! why?
Hello,
I am trying to export out a model from Zbrush to Maya 2013 Via GoZ. I have gone to Preference>GoZ>path to Maya. mapped to C:\Program Files\Autodesk\Maya2013\bin\maya.exe
Next I click GoZ under the tools pallet and for starters, It dose not bring up a window for what I want to launch, (I have 3 packages that are GoZ compatible), it immediately states that file is successfully saved to disk, it lowers my model to the lowest Sub D, then Zbrush just sits there, happy as a clam… Doing nothing. Maya dose not launch.
I have manually added the *.mel file to Maya so I have a zbrush Shelf. This did not seem to fix the issue. Maya still dose not load. 3DS Max dose not load. What dose load (Until I disabled it) Is Carrara, Which is GoZ ready.
Why is Zbrush not giving me a selection Window for software packages?
I am using Zbrush 4R3, Maya 2013 student edition.
I have seen videos for older versions of Zbrush performing this with ease, calling up a software selection window with no fuss…
What am I doing wrong? :confused:
I have searched for an answer to this in the GoZ thread. I have not found an answer that fixes this issue. Is there a way to UNinstall GoZ plugin and re-install it? Could it be a bad install of the plugin?
Are there Any Mods on? I have not seen one Post in Weeks… Everyone on Holiday?
OK…
I have Figured this out.
It was horribly unlcear… Pixologic? You folks need to be more clear in your tutorials for new users. I minor detail, I’m sure somewhere was an Oversight not to mention this…
Next to GoZ in the “Tool” Pallet are 3 small buttons… “ALL” “VISIBLE” and " R ".
Apparently I Needed to hit " R " to reset my preferred GoZ Ap from Carrara to Maya.
Now Maya launches when I press GoZ.
GoFIgure eh? :wink:
