maya ascii import error missing xyz info?
I have maya 8.5 and exported to zbrush a cornell box in maya ascii format. is my maya version okay?
it says its missing xyz data. i can export as obj but is there a difference?
You need to delete the history before saving the .ma file (press Edit>Delete By Type>History). ZBrush will then import the file without problems.
Great thanks!
