I’m working on modelling rocky island like land masses that float in the sky, for my game world environment.
First I created a low poly model in max. I unwrapped it and then exported it to Zbrush and divided it 7 times. I use the 34,000 poly model as my base mesh and project all higher detail with my normal map. I export the model back into max so I can export it into Unreal.
I figured before I spend too much time modelling detail I had better test it by importing it into my level and applying a normal map to make sure it all worked properly.
And sure enough it didn’t. :mad:
The light maps come out with drastically contrasting shadows along the UV edges.
I created a proper almost seamless tangent space normal map which seems to be perfectly ok, as you can see here I plugged the normal map into the material diffuse channel.
So I went and tried a million different things to try and fix it different settings on my static mesh on my material, different lights, object space tangent space normal maps, changing my UV unwrap, different UV resolutions. All I succeeded in doing was making it worse with directional lights.
So I went back to Max and rendered my model with the normal map and it too had the same problem.
So I went back to Zbrush and played some more with the Zmapper. Now I really have no clue how to work the Zmapper I normally just use 3 buttons and 1 slider open configuration, capture current mesh, ray casting max scan distance and create projected normal map. I found using 3DS Max7_TangentSpace_BestQualityconfiguration gave me a almost completely seamless normal map, and I am sure that a little more tweaking of settings could make it even better. However normal maps made with this configuration didn’t in any way fix or reduce my lightmap problem. (I use tangent space normal maps because I haven’t found any existing assets in the game that use object space normal maps.)
But I did discover the before opening the Max7 config that when I clicked on “tangents” under “Display” I get this…
And if I just convert that to black and white voila! It looks just like my model with its baked lightmaps.
After I load the max 7 config it all becomes seamless yet still holds no bearing on what my projected normal map will look like in the end.
So any ideas as to the root of my problem and especially how to fix it would be much appreciated.
