I needed to up these for a render but somehow I think I might have saved them in their current state. Is there anyway I can restore these two things back to their defaults( I don’t know what the default numbers were )?
If you press Preferences>Config>Restore Standard UI then the Compact Memory setting will be reset to its default (though I think this is 256 on all systems). Max Polys per Mesh I don’t think is saved with the configuration, so restarting ZBrush should reset it. However, if you really want to get back to the factory settings then:
- Close ZBrush.
- Rename the ZBrush 4R3\ZStartup\CustomUserInterface4R2.cfg to ZBrush 4R3\ZStartup\BAKCustomUserInterface4R2.cfg to create a back up of your custom interface and settings.
- Start ZBrush. It will start with the factory settings suitable for your system.
- Note down the memory settings then load up your custom UI by pressing Preferences>Config>Load UI andselecting the file you renamed in (2).
- Make any changes then store your cutom UI by pressing Shift+Ctrl+i.
Thank you Marcus:)
