Hello!
I’m having an issue with zbrush keyshot bridge. I send my info from zbrush to keyshot, and it loads fine. I adjust materials in Keyshot, then I go back to zbrush to move some objects around, then I once again send my info over via BPR button- this is where the problem starts. If I had changed the settings of a material, they get overwritten and set back to the settings they were the FIRST time I sent my stuff from zbrush to keyshot. All my material information I adjusted gets destroyed. Is this a known thing? Or is my install messed up in some way? This is a very vital thing I need. I iterate a lot in zbrush and go back and fourth, hence the point of the bridge.
I got one error when installing keyshot, I wonder if it’s related. It states: “Insufficient permissions for interla downs folder: C:/users/username/documents/keyshot 6/downloads Both user and group requires read/write access permissions. This will yield problems during runtime until it is fixed.”
Please help in any way! If this feature worked I’d be so happy. Or if there’s a way to work around this to save my materials in some way?
Thanks,
Dylan
