hi all!
i have a problem:
i made a character with different subtools and different materials per subtool working on zbrush installed in one pc (PC1)
and when i copied that character on another pc (PC2) and i have opened it in zbrush on the PC2, i noticed that some matherials are changed as if those materials don’t exist.
in pc2 i have copied the entire content of the materials folder of the pc1 and all materials are present in the material palette.
i have read something about materials slots used by zbrush to organize different materials.
is there a way either to sincronize material slots in all my pcs or to have the same materials in the same character in all my pcs without using project file?
thanks in advance!
anybody?
i tryed to search about this problem all around this forum and in the net, but i haven’t found any answer…
could you help me, please?
Make sure you either save the whole project (File>Save As - the ZPR format) or save the document (Document>Save As - the ZBR format) as well as the model. Then open the Document first, then load the model. Either way should ensure that the materials stay put. Saving the project is the better method.
thank you marcus! but there is a way to syncronize the two matherials list?
