Material/Texture issues
Hi.
I’m VERY new to ZBrush and only need to use it for a relatively small part of a larger project, namely paining a 3d model.
I have the model as an OBJ and a specific stone material for it as a MTL file and also as a JPEG.
I have my OBJ model in ZBrush and would like to apply the material to it and then paint on small areas of the surface with other ZBrush materials (eg Gold).
However, I can’t seem to figure out how to load the MTL or JPEG as a material because as I understand it, ZBrush uses ZMT files for its materials.
I can load the stone JPG as a texture and apply this to a model as a Texture Map but then I only seem to be able to fill the WHOLE object with the gold material, rather than paint in the materials in specific areas of the model.
Would anyone be able to advise?
Thank you.
